TRANSFERCASE LOWERING
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AK-5GUY, Mar 26, 2003.
  1. AK-5GUY
    AK-5GUY Registered Member
    Apr 24, 2002
    89
    Greensboro, North Carolina
    Does anyone know where I can get a transfer case lowering kit for my 1987 K5? How much do they cost? How hard are they to install, and how long do they take to install? Feedback is greatly appreciated. Thanks!
    Harrison
  2. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    I've always just flipped the spacers on the stock cross member from above the frame to in between the frame and cross memeber. How high is your suspension lift?
  3. AK-5GUY
    Apr 24, 2002
    89
    It's stock now, but i'm getting an echobit flip rear (5 3/4 inches) and 4" tuff country front springs.
  4. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    I took 2 pieces of 1" thick plate about 3 inch by 4 inch and drilled some 1/2" thru holes. Used that to drop the cross member. It has been working great for 2 years.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    At first I used the spacers but I found that they have a tendency to cause dimples in the frame if you land on the t case to hard so now I use 1" square tubing to disperse the load across the frame. Other than that it's a piece o cake. Put a juck beneath the case. remove the four bolts, lower it a few inches, install whatever spacers you use and jack it back it and reinstall the bolts.
  6. AK-5GUY
    Apr 24, 2002
    89
    Where can I get the kit??
    Harrison
  7. AK-5GUY
    Apr 24, 2002
    89
    Harrison
  8. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Skyjacker sells one but you can make your own. All it is, is a spacer. And find out if you need it before you do it. No reason to give back clearance you just installed.
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    can you go more than an 1"?
  10. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    u COULD, BUT when you start lowering it, make sure the engine/distributor doesnt get stuffed into the firewall. I would say no more than 2". and that would be pushing it. Also, i dont beleive anyone makes anything besides a 1" so itd be custom.
  11. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i've seen guys use 1" square tubing, you should be able to get that at any hardware store. it's a lot cheaper thatn the lowering kits too. i saw one kit for about $80. right now i'm using the spacers that came on mine from the factory, but plan on changing to square tubing in the near future. /forums/images/graemlins/grin.gif
  12. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    It would put a lot of stress on the motor mounts as well. Remember, think "tilting" not "lowering"
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I wouldnt loose much clearance, I belive the bottom of my frame is 35". 1" isnt going to hurt.
