Transfercase not doing anything
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eastcoastk5, Sep 5, 2001.
  1. eastcoastk5
    eastcoastk5 Registered Member
    Aug 27, 2001
    24
    Beaufort SC
    I recently installed a 3" body lift on my 85 blazer, and i just noticed that my transfercase doesn't really do anything when i try to shift it into 4wd, do i need to adjust the linkage to the case or is my case done.
    america rises and sleeps under the blanket of protection that we provide.
    Col Jessup, usmc (A Few Good Men)
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    you can try lockin your hubs or take the blazer to a tranny shop an ask them to test drive it
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    One more thing to make sure of is that when you lifted the body you may have in-advertantly cause the vacum line to pop off or tear if the line runs through a body braket anywhere.
    tRustyk5 for President!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  4. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Mine does that too, I think my hubs are bad--my brother parked it in a swamp!--and I think they no longer lock. Try turning the fornt driveshaft by hand with the truck off, see if the front axle locks up. Mine, the left side locks the right side doesn't. Not sure what that means but I've been told that the auto hubs are bad, maybe someone else can explain it better.
    Four wheel drive, four wheel expenses...
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    The hole in your floor board may need some trimming. Sometimes the body lift will not give the shifter enough room to shift into 4 wheel drive. Crawl under and look up to see if it is hitting the tub.
    I thought I was wrong once,
    but I was mistaken
  6. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Yeah, what Butch said. If the t-case was working before the lift, then I would suspect the hole the shifter goes through is in the way and needs to be cut out a little longer.
    I don't think so, therefore I'm probably not.
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Good point!
  8. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    When i got the 3 inch body lift on my 82 i had to adjust the shifter linkage on my t-case to make it work.
    A BIG HAMMER CAN FIX ANYTHING.. [​IMG]
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    ArrowheadK5,
    Just ditch your auto hubs. They're unreliable anyway and will fail when you need them most, much like they did to me.
    Tim
  10. eastcoastk5
    Aug 27, 2001
    24
    Beaufort SC
    thanks for all the help guys
