Transfercase oilchange
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ankarback, Dec 2, 2002.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    Hi
    Just bought a -76 Blazer K5 and I´m wondering what kind of oil i should use in the tranfercase (NP 203).
    The car is used a lot in mud and water so some maintainance i really nessesary.
    Best regards
    /Johan
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    plain old 10w30 /forums/images/graemlins/grin.gif
  3. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    OK, thanks! Good that I didn´t used 75/90 for it.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    is it the same for a 205?
    Where's the stinkin fill hole?? And please dont tell me where the cable goes in. /forums/images/graemlins/smile.gif
  5. beater74
    May 29, 2001
    1,749
    atlanta
    nope a 205 uses gear lube 70/90 , just like you put in yer diff.
  6. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    So:
    NP203=10W30
    NP205=90wt
    NP208=tranny fluid
    NP241(or whatever else they put in K5's)=?
    Are the top three right? What about the other?
  7. blazerman78
    blazerman78 Registered Member
    Oct 16, 2002
    77
    Connecticut
    Dies it really matter if gear lube is used in it? Mine has gear lube in it (I bought it that way) and it seems to work. Also, it's been converted to part-time, if that matters.
  8. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    241 is the same as the 208, dextron III atf
  9. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    DO NOT USE GEAR OIL. The 203 must use 10-30 motor oil. To drain the unit pull the lower bolt on the cover on the back of the case. To refill squirt the oil into the fill hole halfway up the case. 80-90 + 203= kaboom.
  10. 74Chev
    Sep 19, 2002
    102
    Oregon
    The NP 205 uses 80w-90 gear lube. The fill plug is on the back halfway up the case and can be removed with a 9/16" open end wrench. Fill the case not more than 1/2" below the fill hole. You can squirt the oil in with a bottle or buy a pump, or go to the local quick lube and pay 19.95 to do a drain and fill service.
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have used gear lube in my 203 for more than 10 years, had no problems, the chain never stretched and everything was very silent.
    I don't see a problem running gear lube in it, except the drag, which I didn't feel.
  12. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I've heard that gear oil in a 203 will cause the chain to wear out faster. I think it may also damage the oil pump.
  13. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    What oil pump?
    I rebuilt the 203 when I bought the truck, there was no pump.
    And I reused the chain that was in it, and it had gear lube.
    It was a 1 ton 203 though, with a one piece tail housing all cast iron, no aluminum parts.
  14. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    np203 oil pump
    The part about the chain wearing out faster is just what I have been told, I have no evidence of this being true. All I know is that my 205 is a lot stronger than my old 203.
  15. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    it is a little disc the looks like it has been threaded and goes on the output shaft it pumps oil to the rear out put bearing
  16. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Oh that's a pump? well it was fine, and I never changed it.
    By the way, gear oil is just thicker and slicker, so wear would be less on everything.
    The type of pump this one has doesn't get affected by thicker oil, since it's not the sealed type ie: not compressing the oil, just sling it and making waves.
    The chain was more than 20 years old, and I kept it and I drove it hard in a full time configuration for 5 years after that.
    Believe me it's much smoother and I don't care about the parsitic losses ( drag from the thickness of the oil), if I did I wouldn't put 35" mud tires on it /forums/images/graemlins/smile.gif
