Transfercase torque mount
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rusty68, Jan 29, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    I am running a th475/205 combo. Originaly my truck was a 4 speed and had this bracket off the side of the frame mounted to the side of the 205 with 2 bolts. Well my new 205 doesnt have holes for this bracket drilled in it. Should I put them in and use it or what?
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Are you sure this is an NP205 that was destined for use in a GM vehicle? I have not seen any GM NP205s that didn't have the boss and holes for the transfer case mount.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I had my hands on a 205 from a 93 Dodge diesel... it didn't have the holes drilled. Its possible GM stopped drilling them too at some point. I haven't seen that bracket on anything built since the mid-70's.
  4. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    Is the bracket really necessary then if it hasn't been used on anything since the mid-70's?
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Well maybe it is. 1FNHIK5 didn't have his back on the truck at BlazerFest 3 And the back of his TH350 broke in half from torque. Of course he had a ramjet 502 up front. But his trans guy said that the lack of the torque mount caused it. /forums/images/graemlins/confused.gif
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    In the mid 70's after GM went away from the frame mount was when they introduced the link that went from those same 2 holes to the front of the tranny. I think this was also when they introduced the "K" case tranny (but could be wrong).
  7. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    I guess I may as well drill the holes then. I have the bracket, so it wont cost anything but time
