Transfluid in the gas?
Discussion in 'The Garage' started by tecton, Jun 14, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    is it true if you put trans fluid in the gas it will clean the engine of carbon?
    like...1oz per 4 gallons of gas?
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    ive heard of dumping little sips of it down the carb with it running. the high detergent of the tranny fluid is supposed to clean it off, if it doesnt foul out your plugs and smoke out the neighbor. just keep it running by working the throttle cause it will want to stall. when i used to do this awhile ago i used to used a little cold water, the cold water hitting the hot carbon will make it flake off without smoking . just dont use to much, just and ounce or two at a time.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    The water actually turns into steam, thus you are steam cleaning the combustion chamber....
  4. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    sorry, never been inside there watching it work.....
  5. Grim-Reaper
    7,385
    Atlanta
    ATF has a LOT of detergent in it. Dumping it in the gas may clean some carbon off but where that idea came from is truckers. They dumped it in their fuel from time to time to clean out the injectors. Most people with gas engines will send some in through the PCV port.
    I have used top end engine cleaner from the dealer. That stuff works. My company van stuck a valve and the mechanic ran some of that through it and it freed up that valve and save a head job. I was chasing a a miss in my supra I ran some of that through it hoping it was a stuck valve. Turned out to be a burnt valve. /forums/images/graemlins/rolleyes.gif
    Anyway I pulled the head and MAN did that stuff work. what carbon was left in the combustion chamber was flaking off. The valves were pretty clean as well. took mimimal cleaning on the valves to get them back to metal.
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Any idea what the name of this stuff is?
  7. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Just dumping it down the TB or carb will not clean out the venturis or injectors, just the combustion chamber. The top end cleaner cleans the whole Shebang
  8. Grim-Reaper
    7,385
    Atlanta
    Top end engine cleaner IS the name. It's a GM labled product they will usualy have right behind the parts counter with oil filters and spark plugs.
  9. tecton
    Dec 1, 2002
    1,553
    WV
    you guys ever use that ZMAX stuff?
  10. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    i ran atf through a tank of gas. it didn't hurt anything, and i really didn't notice any difference in the way the truck ran after that.
  11. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Reaper is right, TOP ENGINE CLEANER, available at your local GM dealer. When i first got my K-5 it ran like...well it didnt really run. I dumped TEC down the carb(follow the directions). It ran so good after that treatment, cleaned it right out. You can also clean the injectors with TEC when you mix it in with the fuel, but its not recommended cause it melts some bosch injectors /forums/images/graemlins/eek.gif
