Transmision Inspection pan
Discussion in 'The Garage' started by cegusman, May 29, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How do you remove the Transmision Inspection panel(The one in the cab on the hump), I have unbolted it but it appears to be glued down. I have tried to use a screw driver to pry it up but it just bends.
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Mine just came loose when I unbolted it. Someone probably put some sealer around it. Can you get a knife blade between it and the cab floor?
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Different years are assembled differently. I know on my 85 it was basically sealed at the factory. Mine doesn't even have bolts. But, a friend that has a 74 that it just unbolts and pops right out.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Anybody know how or why some do and some don't have the removable tranny humps. I've seen some with and some without. Was it a GMC vs. Chevy thing, or a cutoff at a certain year etc? Anyone.......anyone..........Bueller? /forums/images/icons/wink.gif
  5. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    On my 82 the hump was bolted and sealed in place, i had to use a razor knife to cut the seal and screwdriver to pry it up
