Transmision Inspection panel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, May 29, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How do you remove the Transmision Inspection panel(The one in the cab on the hump), I have unbolted it but it appears to be glued down. I have tried to use a screw driver to pry it up but it just bends.
  2. Grim-Reaper
    7,385
    Atlanta
    Hehehe They used some stout stuff. Try breaking it loose by working a putty knife around it to break it loose. Once you get it off I used some bed rail tape for a camper shell (most parts stores like Autozone and pep girls has it) to reseal it. Worked pretty good. No leaks after 2 years.
