transmission and rear wnd questions
Discussion in 'The Garage' started by matto, Dec 10, 2005.
  1. matto
    matto Registered Member
    Feb 20, 2005
    uncasville ct
    i have an 80 k5 blazer with the 350 and a th350 and np 208 trans case. the rear end is a 12 bolt with an open diff. i need to find out the gear ratio for the rear end so can replace the ring and pinion gears. how could i find this out? also what do i need to do to change the torque converter for the th 350. and advice would be helpful
    thanks in advance
