Transmission back
Discussion in 'The Garage' started by justwhatido, Apr 1, 2005.
  1. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    New Case, reworked the guts replacing all worn parts. Improved the fluid flow to enhance shifting.
    Blacked in the firewall. Will finish assembling the engine tomorrow. Lots of bling in the engine compartment. Black block, red truck, chrome AC comp, alternator, air cleaner, water neck, all pulleys, water pump, fan, valve covers, wire looms, wiring covers, ect. Will run two Optima blue top batteries (yess, I know they are marine) with seperate fuse block (again, marine) under hood for accessories, such as aux lights, (two driving, two fog and two long range lights and rear red fog lights), Mile Marker winch, 12 volt ref/freezer.
    Engine block, transmission and transfer case all black with chrome accents.
    Need a transmission crossmember. Mine too bent to reinstall. Leads anyone?
    Pictures should post Monday.
    Fred
