Transmission Bolt-up Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AGM73k5, Jun 13, 2000.
  1. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Couple weeks back I dropped the transmission and transfer case off the blazer to get the tranny rebuilt and the tcase resealed. Today when I went to bolt them back up they seemed to go into place but the crossmember on the transfer case doesn't want to bolt back up. Right now it is about two inches short of the passenger side frame rail when bolted up on the drivers side. Almost like the frame widened or the crossmember shrunk. I've got a 454 backed up by a th350 with an np203. Anybody have any ideas?
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Use a come along to pull it back in.....
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  3. AGM73k5
    1,246
    Portland OREGON
    Sounds like a good idea, I'll track one down tommorow. Just to make sure I'm on the right track, I'm going to use it to squeeze the frame rails together right?
    ___ __ _ _ ____ __
  4. 73/75 k5
    73/75 k5 Registered Member
    Mar 18, 2000
    38
    ca
    A frame can flex that much outa alignment? Did you remove both cross members when you did the tranny and t-case?
    sean
