transmission cooler
Discussion in 'The Garage' started by anthony stark, Jul 25, 2004.
  1. anthony stark
    anthony stark Registered Member
    Jun 22, 2004
    31
    Houston
    I'm installing one today. Which line should be used from the radiator (top or bottom)? If someone has any advive on how to do this please post. My truck is a full size 87 Jimmy 350 700r4. The cooler is 1.5X17X10.
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Normally, the lower line on the radiator is the input from the trans, the upper is the output from the internal cooler. Factory external installations usually went thru the external cooler first then thru the radiator cooler before going back to the trans. This was done for cold weather situations in order to keep the fluid at a warm operating temp. Lots of people run it thru the radiator cooler firt then thru the external. Anyway, the upper radiator line should be the output
  3. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    TCI Transmissions has a chart on their website that tells which line is pressure and return on all the common trannys--there was a link on here a few weeks ago,I didnt save it,but you can find it by typing TCI on google.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    the lower line out of the 700r4 is the out, top is return... i just did mine, eliminating the radiator..
  5. 88Silverado
    Mar 13, 2003
    2,664
    correct...but if its going thru the radiator it feeds in at the bottom and out at the top /forums/images/graemlins/thumb.gif
