Transmission cooler
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brad, Apr 30, 2000.
  1. Brad
    Brad Registered Member
    Mar 28, 2000
    29
    Little Rock, AR
    I'm going to put a tranny cooler on my 84 Jimmy and need to know which transmission hose going to the radiator (top or bottom)is the input vs. output hose? Thanks
    Brad
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Not sure but a manual will tell you.You have a manual right.It's not the cleanest way but just unhook the top line and have someone start it real quick.If it comes out the tube thats the feed.If it comes out the radiator it the return.You are going to have to disconnect the lines anyway to connect the cooler.
  3. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    The best, cleanest and safest way is to start the truck let it run and touch the cooler lines. The hot one is going to the cooler, the cooler one is return.
    COrey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
