Transmission cooler
Discussion in 'The Garage' started by 1978Blazerk5, Apr 4, 2007.
trans cooler ya or nah
Poll closed Apr 14, 2007.
  1. put the trans cooler in
    38 vote(s)
    97.4%
  2. dont put the trans cooler in
    1 vote(s)
    2.6%
  1. 1978Blazerk5
    1978Blazerk5 1/2 ton status
    Aug 25, 2006
    2,158
    wisconsin
    hey i have a 78 k5 with a 350 th350 dana 44 4.56 gm12 bolt with 4.56 gears and gov lock on 33's. anyways this is my dd would i benifit at all by putting one in.
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    There is no such thing as too much tranny cooling. Put it in.
    -- A
  3. 1978Blazerk5
    Aug 25, 2006
    2,158
    wisconsin
    thats what i thought just wanted some opions
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    what he said
  5. 1978Blazerk5
    Aug 25, 2006
    2,158
    wisconsin
    my friend was telling me by putting in a trans cooler i might lose gas milage is this true
    thanks
    do you have to cut the fitting on the hard line or just put the rubber hose over the fitting
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I would start by installing a tranny temp gauge. If the trans doesn't get too hot then don't worry about a cooler. There is such a thing as too cool. The trans needs to get hot enough to burn off any moisture in the fluid.
    You will not lose gas mileage by installing a cooler. You also don't need to cut any lines, just unhook the proper line and install a hose barb adapter on the line and also one into the radiator then attach the proper hose to each end.
  7. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    If you dont do any heavy towing then I would say you dont really need one.
  8. 1978Blazerk5
    Aug 25, 2006
    2,158
    wisconsin
    well the thing is that it does have a different pan on it for more cooling, i dont really do any towing so,i have a transmission cooler just sitting in my garage
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I run a cooler with fan but have an inline t/stat too. Never heard the fan come on but have felt the cooler get hot so the temp has gotten high enough to open the stat.
    Stat will help the oil get up to temp properly.
  10. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    What T stat setup are you using. I'm thinking about installing one when I rebuild my tranny. The weather here hits both extremes, so I think it might be the way to go.
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I used a mocal one supplied by Earls...go figure!!
    I used the same one for my motor oil cooler too. Both work well.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    BAT's Mocal T-stats
    My undestanding is that Mocal is based in the UK.
    My thinking is that if you put the Aux cooler ahead of the radiator cooler then you make sure that the trans warms up and that any extra heat in the trans will be dumped by the aux. cooler. The downside to doing it this way is that you work the fluid pretty hard when the trans is working hard. I see trans fluid as a consumable, can replace it at will. I don't think of auto trans' that way.
    Since the trans draws it's lifeblood lubrication fluid from the pan, that is where you want the temp sender to be. While you're putting a sender boss on the pan, put in a drain too. Since the fluid is easily replaced, you don't care how hot the fluid got momentarily, you care how hot the fluid is going into the trans. Can always replace the fluid if you saw excess temps in the pan. It's quite a bit more expensive if you miss seeing the momentary temp spike from a sender mounted in the cooler line.
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah it was the one on the left I used for both applications.
