Transmission CRACKED
Discussion in 'The Garage' started by Jeremy_C, Aug 13, 2002.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    Well......when I through my driveshaft this last time, it somehow cracked the transmission. So NOW i get to go buy a transmission. /forums/images/icons/frown.gif
    Anyways, any reccomendations on what to get? I guess just a plain ole turbo-400. Should I get one out of a camaro or anything like that or are they all the same? /forums/images/icons/smirk.gif
  2. Grim-Reaper
    7,385
    Atlanta
    Where is it cracked at? if it's the bellhousing but the case if ok from the pump housing back and not leaking there might be a way to fix it. There is a kit where you cut the stock bellhousing off and a new bell housing bolts on using the bolts that hold the Pump in. I forget who just did this but they are doing a right up on it I think.
    Looks like a stout set up. Drag racers have been doing this for years. Lots of divisions require a scatter sheild (reinforced bell housing to contain the flex plate/ fly wheel if the dicides to let go).
    The guy who did this I think is doing a write up on it.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you cant just go buy a plain old t400 out of a camaro or something unless you are going to have it rebuilt first you will need a t400 from a 4x4 you can use a 2wheel drive t400 but you need to change the output shaft and to do that you need to disasemble the tranny to do it
  4. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    I'll probably be better off to get one from a transmission shop that has been rebuilt. Probably what I'll do /forums/images/icons/smirk.gif
  5. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
  6. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I would get a th400 4x4 case it is alot stronger in the rear of thr tranny.
    colinthe
