Transmission Filter
Discussion in 'The Garage' started by Madbomber88, Jul 4, 2005.
  1. Madbomber88
    Madbomber88 1/2 ton status
    Feb 7, 2001
    185
    Mass
    Went to replace the filter on my stock 91K5 with a 4l60 yesterday. Is the filter just supposed to stick up in the bottom of the tranny? It is kid of loose and would imagine it could work its way out and fall out into the pan. Anyone else have this problem?
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    did you remove the old seal
    it is kind of loose, but it can't fall out since it will rest on the bottom of the pan when its reinstalled
  3. Madbomber88
    Feb 7, 2001
    185
    Mass
    Ok, that was part of my question, it's ok for it to rest on the bottom? I wasn't sure if that prevented it from sucking up fluid. The seal is blue and ribbed, right?
    Thanks for the quick response.
    -Tim
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yes the seal is ribbed, just make sure you get the old one out and the new one in and you're good to go
