Transmission fitment???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlackWidow, Apr 22, 2007.
  1. BlackWidow
    BlackWidow Registered Member
    Jan 9, 2007
    26
    Charlotte NC
    Is a th700-r4 (tl60) the same tranny we use? I found one from a trans-am used and rebuilt. (my tranny is shot) So I was looking at this one to buy!
    Any help would be great!!
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    A 4wd trans has a thicker bell housing with 6 bolts holding the convertor inspection cover on whereas a 2wd trans uses 4 sheet metal screws to hold the cover on.
    You would have to completely tear the 700R4 apart and swap in a 4wd shaft in order to use it or install a 1 7/8" spacer between the trans and adapter.
