Transmission fluid direction
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ignato, Jul 1, 2003.
  1. Ignato
    Ignato Registered Member
    Feb 6, 2003
    32
    Phoenix, AZ
    I have an 88 with a 700R4 Tranny. Do any of you know which way the transmission fluid flows to and from the radiator? (Is the fluid being pushed OUT of the upper radiator connection, or vice versa?)
    I'm installing an in line transmission temp guage, and wanna make sure I have it reading before the factory and aftermarket tranny coolers. Any help is appreciated.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Bottom line on radiator: flows to radiator. (use this one - if you must put the sender in the line, try to get it at close to the transmission as possible)
    Top line on radiator: flows back to transmission.
