Transmission guys..help..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Neil, Jun 29, 2001.
  1. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    '78 K5 400sb 4x4 AT. not sure if TH350 or TH400. My parking stopper in tranny has wore out or broke or something. Is it hard to replace? Should I have to pull the tranny or replace it while on the truck? My K5 tries to roll away!
    How can I tell if TH350 or TH400 transmission? shape of pan or somethin?
    Neil H. Alabama '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Bring the pan to the local autozone or pep girls they have pan chart to match your tranny up.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    th350's have a square pan with a corner cut out.
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Hey, hope this helps.
    http://k5.8m.com What more is there to life?**
  5. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If it's the stock trans, then it is a Turbo 350. Sounds like your parking pawl is broken. [​IMG] I'm not sure if you can replace it by just removing the pan or not.
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Also check to make sure that the linkage hasn't slipped or is out of adjustment. If it's messed up the problem could be that the tranny isn't quite going all the way into park, even though the lever says it is.
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Im not super familiar with GM trannys but I do know that on Fords you dont have to r&r the trans to replace the park pawl but you must pull the t case and extention housing to remove the pivot pin that goes through it.There also may be spring that holds the park pawl away from the park gear that that pin also goes through.Its been a few years since Ive had a GM tranny torn down but I dont think you have to pull the whole thing.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  9. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    ........but before you tare anything apart make sure you have propper shifter opperation outside the trans and if you dont find anything outside ,pull the pan and see what you can see in there.Good luck.
