Transmission Help
Discussion in 'The Garage' started by dirtyburb, Jul 5, 2004.
  1. dirtyburb
    dirtyburb Registered Member
    Apr 3, 2004
    16
    the tran shop just finished my th350 and well the output shaft is to long. they said the theres only one th350 and the out put is not wrong becose there is only one. so what do i do im trying to mount it up to my np205 but it wont work. i know there is another output i just need to find it does anyone know where i can. thanx
  2. dirtyburb
    Apr 3, 2004
    16
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    I'd look at Advanceadapters.com they're sure to have what you need or the info your trans shop is lacking. /forums/images/graemlins/waytogo.gif
  4. dirtyburb
    Apr 3, 2004
    16
    all advanced adapters has is the output for a 700r4 to hook up to a np205 i just need the stock one someone must know where i can get this iv looked all over the net im begging please /forums/images/graemlins/1zhelp.gif
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    did they put a 2wd shaft in it?
    Chris
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    acording to my book, the 4x4 th350 output shafts are all the same. /forums/images/graemlins/dunno.gif
    how much longer is it than you need? they might have put a 2wd shaft in it /forums/images/graemlins/dunno.gif
  7. dirtyburb
    Apr 3, 2004
    16
    it sticks out of the adapter about 3 inches
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    did you put the tcase on it yet?
  9. dirtyburb
    Apr 3, 2004
    16
    no becose it wont get close enough to bolt to the t-case after you put the sleeve on it, the adapter is about 4-5 inches from the t-case, and i thought they used a longer trans. output on the np208 than the 205 if what yall are saying is true ill have to figure it out ill try and post some pics tomarow
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 208s did use a longer output shaft. my book only shows upto 80, in 81 is when the 208 started 82 most vechicles got a 700r4.
    if its 4-5 inches from the adapter and tcase when mocked up, then it sounds like they put a 2wd output in it.
