Transmission is dead... have a question
Discussion in '1982-Present GM Diesel' started by rocko, Sep 3, 2002.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Hey guys, this is Pam (Rocko's wife). We have a lifeless computer at home so I'm posting this for him since he doesn't have access. He needs to know if the 700r's from a diesel blazer are the same as from a fuel injected? He's been offered one from an '85 fuel injected and just wondering if it will bolt right up to the diesel. And is the torque converter also compatible?
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The transmissions are virtually the same and will bolt right up. However, the gasser torque convertor has a higher stall speed than the diesel. Also, the governor on the gasser will cause the shift points to be higher. I've been told that a gasser 700 won't hold up behind a diesel, but I've been running a 1990 gasser 700 behind my 6.2L for over 5 years and 50,000 miles with no problems. I actually prefer the higher stall speed and shift points.
    Casey
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    A new governer for a 700 is under 20 bucks, and if you tell them you have a diesel they will give you the right governer for your truck. The governer is under that circular shaped lid that sticks out of the drivers side of the tranny, just pry the lid off and the governer comes right out. You could probably get a rebuilt TC for under a couple hundred bucks, then your 700 would be exactly the same as a stock diesel 700
  4. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Casey and Dan, your info really helps a lot and answers several questions. /forums/images/icons/smile.gif /forums/images/icons/smile.gif /forums/images/icons/smile.gif
    One more, would it be beneficial to stick with a diesel TC or just buy a new gasoline type TC for a 700r? Casey, what did you use?
  5. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    You can use the old TC from your diesel. With a TC from a gasser you dont become lucky. Thus you need a higher rpm for start.
