Transmission Issue
Discussion in 'The Garage' started by armyfiredawg, May 12, 2006.
  1. armyfiredawg
    armyfiredawg Registered Member
    Apr 5, 2005
    62
    Sacramento, CA
    I have a 89k5 with a 700r4. I just got done rebuilding my np241 transfer case and i also put on a 1" TBI spacer.
    Here's the problem. Ever since i did all that, my transmission shifts really high into second. And its driving me crazy trying to figure out why!!:mad: I think it might be because of the 1" spacer i added, that it is somehow throwing off my tranny. Could this be it? And how would i fix it?
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    did you adjust the T.V. cable after putting the spacer on?
  3. armyfiredawg
    Apr 5, 2005
    62
    Sacramento, CA
    No i haven't. I thought there was enough. Do i adjust it at the Tranny or TBI?
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    It sure could be the TV cable adjustment, and maybe the way the TV cable bracket is positioned relative to the carb now, with that spacer moving things around. Here's a little bit about the importance of having that all adjusted properly (it's not just a "kickdown" cable):
    http://www.tciauto.com/instructions/gm_tv_cable_adjust.htm
    By the way, did you add the 1" spacer for needed linkage clearance, or for totally miraculous gains in both power and fuel economy at an equally miraculous low price?
  5. armyfiredawg
    Apr 5, 2005
    62
    Sacramento, CA
    lol, the latter of the two. Thanks, for the link. This will help a lot!!:bow:
