Transmission jerking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, Feb 4, 2003.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    well when i shift my 87 Gmc Jimmy from park into drive it has somewhat of a jolt(700r4). Is this normal.....should i hold the brake while its engaging or just let it go. which is less harmful to the transmission.
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    what's it idlin at? got good ATF? there is too much friction in the converter, and it's prolly either bad ATF or high idle.
  3. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    it idels pretty high no shake in the motor. I had changed the ATF when i put the tranny in. But when i check the fluid, the first time i check it it looks kinda blackish and the second the fluid looks really clean(like brand new). I think that was left over from the old fluid in the torque converter. I had a previous transmission in my truck and it jolted the same. when i say jerking i mean it goes into gear kinda hard and then pulls foward, maybe its normal or something else?
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    if it did it before i'd say it's gotta be high idle. that's assuming you have a new converter as well.
  5. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    actulley i did used the torque convertor provided from the transmisson that i had put in its not new, and my truck used to idle really Shi**y. I just changed all wires plugs ingnition module and coil, that is why it idles higher.But previosly when it idled slower it still had a jump.I think everything is fine but when shifting from park to drive should i have my foot on the break or not. Which is easier on the tranny?
