Transmission Line Question
Discussion in 'The Garage' started by broc944, Nov 5, 2006.
  1. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I have a leak in my rubber line between the radiator and aftermarket transmission cooler. I want to use braided stainless steel lines, but need to figure out the size of fittings I need to order.
    The questions I have are:
    1. What is the size of the fitting that screws into the radiator?
    2. Would -AN6 be the correct size braided line to use for a replacement?
  2. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    I *think* the fitting in the radiator is 1/4" NPT... just pulled mine, and it looked like that.
    I donno 'bout the line size.
    -- A
  3. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Line size is -6 (3/8"). The fitting is not pipe thread, is is a double flair like brake fittings.
  4. dremu
    Feb 27, 2000
    15,952
    443
    I stand corrected. I will be careful with my brass fittings then and not try and put NPT's on there. (Come to think, it looked finer threaded than pipe.)
    -- A
  5. Slapperbar
    Nov 29, 2005
    2,747
    3
    I think you'd need a 5/16" flair to -6 adapter from Earls. Or... you could call Summit and they'll tell you what you need.:)
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Can also get such an adapter from an industrial hydrualics supplier.
  7. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    line size..
    MOST tranny lines are 5/16",with fittings that have 1/2"x20 threads...some heavy duty TH400's I've seen used 3/8" lines with 5/8x18 threads..
    I hate using plain galvanized steel lines on my tranny lines,they only last a year or two here thanks to road salt eating them..
    I'm tempted to have custom hoses made to fit,but I've read that the steel lines themselves act as a cooler,and eliminating them might increase tranny fluid temparature..but leaky steel lines could let the tranny run dry!--dammed if you do,dammed if you dont!..:doah:
  8. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Were you thinking of stainless tube vs. rubber?
    Stainless is a poor thermal conductor.
    While it's true that GM uses steel tube for a PS cooler on later models, I suspect that a small aux cooler would more than offset the difference btwn steel tubes & rubber hoses.
  9. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    The reason I want braided lines is for protection from vibration. Second time the rubber hoses have started leaking due to vibration.
    I hate the hose clamps, and I also do not really care for rubber hoses that attach the cooler to the existing lines and radiator.
    Vibration is what causes 90 percent of all the needed repairs I make on my truck. If a hose starts leaking, it is going to be replaced the -AN way from this point on.
  10. 70GMC
    70GMC Registered Member
    Nov 1, 2006
    40
    Reno, NV
    yeah you're going to need a 5/16 to -6 adapter like slapperbar said. i have my tranny cooler hooked up with an fittings and braided line. i used a b&m supercooler set up for an fittings, and i used a permacool thermostat
