Transmission Lines Question
Discussion in 'The Garage' started by RLBstein, Jul 15, 2003.
  1. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    When I rebuilt the blazer, I decided to use rubber lines for my transmission instead of the hardlines that were there ( a lot easier to reroute). I am now starting to wonder if this might cause any problems. I'm not talking about a few sections of rubber line, I mean the entire thing from the output of the tranny to the cooler in the radiator, to the external cooler, and then back. TIA
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    As long as the rubber lines are tranny lines and they are adequately protected it should be fine...
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Just make sure that they aren't routed anywhere that they will come in contact with metal. As you drive down the road rubber + metal= hole in the rubber (if theres vibration), and if its a tranny line it could cause a fire or blown tranny.
