transmission lines
Discussion in 'The Garage' started by k51977blazer, Mar 7, 2007.
  1. k51977blazer
    k51977blazer Registered Member
    Feb 11, 2007
    71
    Ashtabula ohio
    Ok my lines on my 1977blazer 350 4x4 started leaking so i had this dumb idea to cut the line and replace with a rubber hose well that didnt work of course so my question is i want to go to the autoparts store and get steel lines but i need to know how long they are does anyone know how long they are i know lmc has them allready prebent but i really dont have 55 dollars to spend on each line.ANy help would be greatly appreicated
    thank you
  2. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    5/16 lines and any way you look at it you will need to cut and flare.
  3. diesel4me
    Jul 24, 2003
    17,581
    945
    Massachussetts
    yep..
    5/16" lines 60" long will fit nicely..and you will only need to cut and splice them if you have an aftermarket cooler installed..if not,they will reach and screw right into the tranny and radiator..might have to put a "loop" in one if its a bit too long...I run my tranny lines up in the engine bay,instead of clipped to the OEM brackets on the oil pan..they rust away quick enough around here,without them getting salted down in their original location..:crazy:
