Transmission link cable to the carb.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ellero, May 3, 2007.
  1. ellero
    ellero Registered Member
    Jan 25, 2004
    66
    Covington, Georgia
    The cable length and end connector on the kick down cable for my newly installed, but used T-350 is much different than the one on my old broken 700r4. Does anyone make a conversion and if not, how can I properly connect it ton my 84 q-jet carb. I have purched a used non computer controlled Q-jet that might hook up just fine (dont know yet as it needs to be rebuilt) but for the time being and until I can get all the new ignition stuff set up, is there a way to make the 78 T-350 kick down cable work on the 84 computer controlled carb?
    John
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    buy the kickdown cable for a 84, or rig up a different bracket
  3. ellero
    Jan 25, 2004
    66
    Covington, Georgia
    I had one but it would not fit the T-350 tranny. The housing was to big and I was not about to drill out the case of the tranny to make it fit.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    T-350 has a cable? I thought it just used a vacuum line.
  5. dave_90_blazer
    Jan 1, 2004
    688
    t350 uses a vacuum line to the madulator valve, and a cable for kickdown
  6. Blue85
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Oh yeah.
  7. Blue85
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    What about the 3/4 or 1-ton trucks from the mid 80's that didn't get a 700? Do they have the right bracket?
  8. dave_90_blazer
    Jan 1, 2004
    688
    yes try a bracket from a 82 or 83, those should have had a 350 trans
