Transmission link cable to the carb.
Discussion in 'The Garage' started by ellero, May 3, 2007.
  1. ellero
    ellero Registered Member
    Jan 25, 2004
    Covington, Georgia
    The cable length and end connector on the kick down cable for my newly installed, but used T-350 is much different than the one on my old broken 700r4. Does anyone make a conversion and if not, how can I properly connect it ton my 84 q-jet carb. I have purched a used non computer controlled Q-jet that might hook up just fine (dont know yet as it needs to be rebuilt) but for the time being and until I can get all the new ignition stuff set up, is there a way to make the 78 T-350 kick down cable work on the 84 computer controlled carb?
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    Memphis, TN
    Since you are swapping it out soon just leave it for now and if you need to hit second use the lever on the column.
