transmission linkage ?
Discussion in 'The Garage' started by BL1TZKRIEG, Jun 24, 2005.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    I searched forever for this with out an luck
    I'm going to be lowering my transfer case 3/4" maybe more after having vibrations from a 4 " lift 5 1/2" blocks in the back I really dont want to but My t-case angle is too severe I was wonder if I will have to adjust my transmission linkage or t-case linkage if I only drop it a little bit.
  2. dremu
    Feb 27, 2000
    15,957
    448
    East of San Francisco
    Tranny linkage is easy to adjust: put lever in park, loosen bolt, make sure tranny is in park, tighten bolt.
    T-case linkage does not go to the body on older trucks -- what year/flavour is yours? -- so it may or not may be an issue.
    Karnak The Invincible sees a shackle flip in your future. :haha:
    -- A
  3. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    thanks for the tip :)
    it's a NP241 1990
    yes I want to ditch the huge freaking blocks, what do you recommend getting a shackle flip or new springs ?
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    shackle flip, the angle will get better on you pinion most likely, with your 241 you may have to make a linkage adjustment
  5. dremu
    Feb 27, 2000
    15,957
    448
    As Resurrected_Jimmy says, the shackle flip will get you a better rear pinion angle. It also retains the stock springs, which are likely flexier than lift springs.
    Your newfangled truck has that floor shifter thing, so yeah, you'll hafta tweak something. Donno what, as my only 81+ truck is bone stock :haha:
    -- A
