Transmission not shifting sooner????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlackWidow, Apr 6, 2007.
  1. BlackWidow
    BlackWidow Registered Member
    Jan 9, 2007
    26
    Charlotte NC
    Hey guys, I have a 87' K5 4x4 with a 350 and a 4 spd AT.. For some reason it doesn't want to shift from 1st to 2nd until 20mph, even under light throtle. Is there a way to fix this or is this just normal??
    Any help would be gratly appreciated...
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You need to "set" the TV cable. If you keep driving it you will need a rebuild VERY QUICKLY.
  3. BlackWidow
    Jan 9, 2007
    26
    Charlotte NC
    I tried to adjust the tv cable but I believe my "D" button is broken off, I dont feel it back there when I go to push it. Is there any solution for this or will I need a new one?
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  5. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    After the cable is adjusted the approximate shift points should be 15 to 18, 25 to 30 and 40 to 50 MPH at very light throttle depending on tire size and axle ratio. From link
    http://transmissioncenter.net/subject.htm
