Transmission Oil cooler
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JHG, Dec 26, 2002.
  1. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    I am putting a huge oil cooler on my ´81 K5. When I placed it in front of the radiator I noticed it blocks nearly half the rad.
    I know that ther should be a less heat from the trans into the rad because of the cooler and the that the heated air will pass the rad and cool it a bit, but I was vondering if this block from the cooler could lead to an overheating situation.
    I was thinking I should perhaps put the cooler somewhere else with its own fan but are not sure where to put it.
    My truck had a 2 row radiator without overheating but has a 3 row rad now so it should not be a problem but still....
    My truck has a 350ci/TH350, 4.88 and 38" tires.
    So if I sum it up:
    1) Could this lead to an overheating situation?
    2) Should I put the cooler somewhere else?
    Thanks in advange,
    Jon H. Gudjonsson
    /forums/images/graemlins/k5.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I dont think you'll have a problem and that is most likely the best place to put the cooler. I say stick it on and see what happens. /forums/images/graemlins/thumb.gif
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I would say No and heres why
    I turned my A/C condenser into a tranny cooler and I think you know how big that is. /forums/images/graemlins/shocked.gif. I don't know how warm it gets in Iceland, But in Denver Colo it was quite warm here last summer and my 83 did just fine. The way I did mine was I ran the hot ATF to the cooler then back though the rad. so I would not over cool the ATF and so far it looks like it pulls some of the heat out of the rad. Sometime soon I will put a temp guage on it to see what it's doing.
    Eric
  4. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    Thanks, I will try it then /forums/images/graemlins/smile.gif
    Its definitely a lot hotter in Denver than in Iceland /forums/images/graemlins/wink.gif
    Jon H. Gudjonsson
