transmission or x case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85GMCJimmy, Apr 15, 2001.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    well i was driving down the road, and heard a clunk and could not go forward or backward, i tried every gear, is it the x case that's broke or the transmission? it's a 700r4, and i have a lead foot sometimes. you can see the drive shaft move a little when put in a gear, but not enough to go, when testing out the gears, then i put it in park you could hear a hear grinding sound.
    <P ID="edit"><FONT SIZE=-1>Edited by 85GMCJimmy on 04/15/01 07:41 PM (server time).</FONT></P>
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Need a little more info. Try disconnecting the rear drive shaft and engaging 4 hi or lo and see if it moves. Could be axle related. With the drive shaft moving a little, hard to say.
  3. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    i think it is your x case but with out more info its hard to tell
    Bandit
    (Your right i dont understand the jeep thing)
  4. 85GMCJimmy
    Feb 21, 2000
    83
    South Carolina
    when trying other gears, such as drive and such, when put it back in park i heard a gear grinding sound,
  5. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    I had the same problem with my 77 K5 the other day and it turnes out I didn't have my transfer case fully engaged. I just got my Blazer Friday and am not used to it yet.
