Transmission poll
Discussion in 'The Garage' started by neverendingproject, Jun 19, 2006.
Which transmission?
  1. 700r4
    21 vote(s)
    30.4%
  2. nv4500
    26 vote(s)
    37.7%
  3. other
    16 vote(s)
    23.2%
  4. nekkid and dont care
    6 vote(s)
    8.7%
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Im going to need a new transmission soon as mine is mostly stock and ive got a 383 in front of it. I would like some honest opinions on what transmission should be next.
    I have 3.73's and I would like a nv4500 but they cant be found, and a guy can rebuild a 700r4 with EVERYTHING for a fair price.
    I found a place where I can get the 4500 used for 700 and and the 700r4 new and super-built for about 700-800.
    My only considerations is getting a different bellhousing for the 4500 and making new crossmembers or shell out money and "hope it doesnt break" for the 700r4.
    or are there any other suggestions?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    You won't have to "hope it doesn't break" if your trans guy can build that 700R4 properly beefed, like these:
    http://www.bowtieoverdrives.com/
    (edit - spelling error)
  3. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    sm465 for the win.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you decide to go with a 700R4.............
    IMHO dont rebuild the 700R4 if it is the orginal one that came in your truck. I am assuming were are talking about the 700r4 in your 84 K5 listed in your bio.
    The old 700s had many weaknesses that rebuilding and even beefing up wont cure. You need a 88 or newer tranny. They had beefier stronger parts better pumps and internal changes to fix the problems with the older units.
    IMO your best options are:
    To get a tranny from Bowtie overdrives as said in above post.
    Or
    Buy a new 700r4 (4L60) from GM.
    or
    Find a 88+tranny at a junkyard and have it rebuilt/upgraded.
    I would not waste any money having aan older model 700 rebuilt.
    Also
    Be sure to get a new torque convertor and flush out the trans cooler/lines
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I'd go with the SM465, but it has no OD, so NV4500 is your best option.
    I wouldn't even consider a slushbox. You will not regret having a stick, no in a million years. :)
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Even if I went with the 700, what stall speed should I go with?
  7. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    id say go with the sm465 if od isnt a biggie... nv4500 otherwise
    cant beat the control and dependability of a manual
  8. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    What cam are you running? Your cam usually determins the stall speed for best performance. In a 4x4 i would go the lowest recomended stall.
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    built 700
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Im running gmpp 383 cam which is supposed to make over 400 lb-ft from 2500rpm on up.
  11. berserker
    berserker 1/2 ton status
    Nov 19, 2005
    127
    columbus,ohio
    go with the manual nv4500 or bomb proof sm465:waytogo:
  12. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    i hav a sm465 and it is great!!!super low 1st gear!!!
  13. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I just talked to the trans. guy and he said he could do a 4l80e for a little less than the 700 but it would be a manual valve body ( no electronics), so this is now an option.
  14. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    now your talking....
  15. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    i'm looking for an nv4500 myself. they are so dang expensive. i live in southern california and all the transmissions are out of state it seems (well, on ebay). i havent seen one below 1200 rebuilt. the conversion kit for a 205 ten spline is about 1000 also. maybe ill just have to start picking my money tree in my back yard....j/k. anyone with experience building a trans crossmember? what kind of mount should i use for an NV4500? thanks to anyone who knows.
  16. cheyennek20
    cheyennek20 1/2 ton status
    Nov 5, 2005
    751
    Wishing I was in Baltimore
    X3 , If it'll last behind a BBC, then a 383 won't kill it.:D
  17. CUCV2
    CUCV2 1/2 ton status Premium Member
    Mar 22, 2007
    1,601
    80
    New England
    Do a search on the manual valve body. I read they can be a PITA to install right. If you have the right transmission guy and get past that, the shifts may be somewhat rough. If that is OK with you then, you may need a floor shifter to make the shifts. Manual valve body + Install + Shifter = close to what a TCI controller is. CompuShift controller sounds better than a TCI. What does all this mean? 4L80E can be an expensive choice. But then again so can the NV4500. I opted for the 4L80E with the compushift.
    Oh yeah, and there are the driveshaft lengths to look into. Some times keeping it simple is the best option. If you have the 700R4, a built one might be the best bet.
    My $.02
  18. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Look at the dates of the poll I think he already has the 4l80 in the rig :wink1:
  19. CUCV2
    Mar 22, 2007
    1,601
    80
    New England
    Good call :bow:
  20. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Actually, I went with the computer option. There is more tuning I have to do cause it acts wierd sometimes, but overall, its kicks some serious a$$. I love the 4l80e and not ever having to worry about a higher HP motor breaking it is an amazing feeling.
    Btw I ended up getting the rebuilt and enhanced 4l80e for free, and I only had to buy the controller.
