Transmission pressure gauge?
Discussion in 'The Tool Shed' started by jms, May 22, 2006.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Getting ready for a tranny rebuild (nope, not the truck; I hope I won't need that anytime soon - it's my '61 Buick :D ) and I'll need a tool to measure pressure. Recommendations where to get one would be cool; I assume my old engine compression gauge would not be suitable. Also, this is not for professional use.
    Advice is appreciated, thanks, michael
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Poke around on www.bowtieoverdrives.com I seem to recall that they sell a pressure gauge and hose for setting up the throttle valve cable on a 700R4 properly.
  3. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    The bowtie people kick butt:bow::bow:
    George
  4. jms
    Jan 24, 2001
    1,683
    Harry, thanks for the link; they do have a gauge as part of the istallation tool kit.
    Thanks, michael
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i am wondering if i should do this instead of taking it to a tranny guy.
    700r4
  6. jms
    Jan 24, 2001
    1,683
    I'm scared of touching my 700. I'm mulling over the output shaft issue when mating up a 700 and a 203 - I'll probably end up drilling the 203 rather than tearing into what appears to be a perfectly good 700...
    I do have professional help for the '61 Buick - the recognized transmission guru :bow: for those years is going to assist. He's 86, so I'll better do it soon...:D
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    me to. there is so much stimiga attached to setting up the tranny right, it just scares me to jack up a thousand dollar tranny
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Swapping the output shaft is EASY. I helped a guy swap a 4WD output shaft into the '87 Corvette trans that I have. It took less than 45 minutes and we weren't even working fast. Pull the front pump, unhook the large band around the main cluster, then lift the whole cluster/gear assembly out as one unit, unclip the C-clip that holds the output gear in place and you're half done already. :) Slide in the new output shaft, clip it, then reinstall the rest and seal it up. I was amazed at how little effort was involved.
  9. jms
    Jan 24, 2001
    1,683
    Sounds like it, but I've never touched a tranny before...
    The way I see it, I have ONE good 700R4, but TWO NP203 range boxes... so I figured I'll try and drill 1 range box first. That way, if I mess it up, I have enough left over for plan B....:D
