Transmission problems HELP!!!!!!!
Discussion in 'The Garage' started by mogas, May 25, 2004.
  1. mogas
    mogas 1/2 ton status
    Apr 5, 2004
    118
    Flagstaff, AZ
    85 suburban 700r4 /forums/images/graemlins/thumb.gif
    Started the truck, put it in reverse and it felt like I had locker bind while backing up. /forums/images/graemlins/shocked.gif I have no locker or limited slip and the hubs are free. /forums/images/graemlins/confused.gif I put it in drive and start off to the office. Come to stop sign and then when I applied throttle the tranny would slip. /forums/images/graemlins/angryfire.gif
    If I shut the truck off then restart it it is fine for a mile or so, shifts normally with normal power then back to slipping. When slippage is occouring, it does so in all shifter positions including reverse. /forums/images/graemlins/dunno.gif
    ANY HELP IS APPRECIATED!!!!!!!! /forums/images/graemlins/1zhelp.gif
    Thanks,
    Dave
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    check your tranny fluid. you may find that its low, if not then i say time for a rebuild /forums/images/graemlins/frown.gif
  3. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    It is common for 700's to do that. Unfortunately it does sounds like time for a rebuild. Goodluck.
  4. mogas
    Apr 5, 2004
    118
    Flagstaff, AZ
    Tranny fluid is nice and the level is right on. /forums/images/graemlins/dunno.gif
  5. gm guy
    May 1, 2004
    151
    If you don't want to get it rebuilt look for a 88 or newer 700-R4 they are stronger. The pre 88 ones had weeker clutches I believe.
  6. mogas
    Apr 5, 2004
    118
    Flagstaff, AZ
    I have a turbo 400 from my friend's truck (1990 4x4) How hard is it to retrofit??
    Do I need to find an adapter for the transfer case or will mine work?
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will need the entire setup, the adapter will not work, its a different pattern on the tranny side. the tcase also is different, the output for the th400 is 32 spline while the 700r4 is 27 spline.
  8. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Your Torque Converter might be going bad. The Torque Converter may not be locking up properly, which is why it is slipping in all gears and not just one or two. Unfortunately when the Torque Converter goes out it can sometimes take the rest of the transmission with it, thus just replacing only the Torque Converter would not be recommended.
  9. mogas
    Apr 5, 2004
    118
    Flagstaff, AZ
    O.K. I can get a 241 out of an 88 1 ton for 500$ at the local wreckers. What else would I need to convert to turbo 400??
    Is 500 bucks too much for that case???
  10. gm guy
    May 1, 2004
    151
  11. mogas
    Apr 5, 2004
    118
    Flagstaff, AZ
    Are the newer TH400's downshifted by an electrical switch like the one in my 442 or are they different?
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    500 is way high for a tcase. should be half that at the most. put an add up in the forsale section, someone should have one.
    im not exactly sure of everything you will need, but i can help some.
    oyu will need:
    tranny, adapter, tcase, torque converter, kickdown stuff (not sure what is needed)
    you may need drive shafts, but not sure. the crossmember you have should work also. /forums/images/graemlins/waytogo.gif
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    AFAIK all th400 are electronic kickdown.
  14. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That's too high for the whole setup!
