transmission question (700R4)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sosamantx, May 3, 2002.
  1. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    ok, i've finally got the blazer running (sorta), but now the transmission is acting up (won't upshift unless you let off of the gas, and then it seems to go to 3rd of 4th?). anyway, i had this 1 guy check it out (a friend of a friend that does tranny work), and he said it needs to come out. my question to you all, does anybody have a shift kit in their transmissions?, and any pros or cons to having a shift kit in your rig?
    my pics in case anyone is curious, i'll have to create a webpage later on and update it with what all i did! /forums/images/icons/wink.gif
    http://sosaman.home.texas.net/blazer1.jpg
    http://sosaman.home.texas.net/blazer2.jpg
    http://sosaman.home.texas.net/blazer3.jpg
  2. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    the main thing here is to have your TV cable hooked up right. From the sounds of it it seems like you have to much tension on it. If your throtle valve is allready pressed in from having the cable too tight then it will cause it to start on 2-3-4 gear.
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    are you sure your tv cable(cable from transmission to throttle linkage) is hooked up, not broken, adjusted correctly? this cable controls the shifting of the transmission.
  4. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    Ditto on the cable, put a shift kit in, you will like it. I put the street version in mine vise the RV. It comes in the same kit you just pick what components to put in.
  5. sosamantx
    Aug 14, 2000
    393
    somewhere in Texas
    the guy that looked at the tranny, drove it, and adjusted the cable somewhat, i don't think it was really out of wack to much? i am going to take it to this other tranny shop to get another opinion, but they want (worse case scenario) $1500-1800, whereas this other guy, said about $800-1400. anyway, i've always had a shift kit on my other vehicles, just was wondering about the blazer.
  6. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    before you spend that much on a rebuild, checkout a GM factory Reman, i got mine for $1200 with a 36 month 50,000 mile warranty. a local shop installed my engine tranny and new xfer case for $860 labor and fluids. just a tranny swap should be a few hundred. or a raptor for $1500, just no GM warranty, but supposed to be a really well built tranny
    chris
  7. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Unhook the detent cable and see if that's the problem. It sounds like that's the problem. This is what tells the transmission to disengage the torque converter and drop a gear.
    I read your other posts and if I were you I'd go buy a remanufactured one from a local auto parts store and put it in myself. The most difficult part is getting all the bolts off varioius parts (especially the crossmember) and having a weekend to spend doing it if something goes wrong.
  8. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I was going to mention as well that if you get the same story from another shop, I would consider going back in with a Raptor. Search on this forum and you will find a link to their home page. Depending on where you are in TX, you can possibly go pick the thing up yourself and save the shipping costs.
  9. dyeager535
    26,979
    Just don't leave that cable off, you WILL fry a 700 quickly without it hoooked up.
  10. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Everyone is correct about checking out the T.V. (Throttle Valve) cable. If you do need a new Transmission, I just put a new "Level 3" 700R4 from Bowtie Overdrives <a target="_blank" href=http://www.700r4.com/sitemap.html>http://www.700r4.com/sitemap.html</a> in my 90 and I am very happy with it. All that Bowtie builds is 700R4s and ships them all over the world. I wouldn't go anywhere else. I also installed a 3 way switch and light on the TCC (Torque Converter) Solenoid so that I can disable Converter Lockup, allow the computer to control Lockup, or to manually force Lockup. The blue idiot light comes on anytime the Converter Locks. While I was at it, I install a new cooler and an AutoMeter Trans Temp gauge.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    700R4s don't have detent cables, they have TV cables. The TV cable functions like the vacuum modolator and cable of a TH 350 all in one...and the tranny will be fried in short order without it.
  12. sosamantx
    Aug 14, 2000
    393
    somewhere in Texas
    does anybody know of the site to the place that makes the raptor?? i've tried doing a search on here, but came up with nothing. of course i am impatient!! /forums/images/icons/frown.gif
    anyway, i found this on lycos doing a search, but it looks like a distributor?? i'd like to actually go to their website if they have one?
    http://transmissioncenter.net/All%20Transmissions.htm#700R4
  13. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    that is the right place
