transmission question
Discussion in 'The Garage' started by hidesertwheelin, Jan 25, 2007.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    When my transmission shifts from 2nd to 3rd, I can feel it shake the whole truck? My rear pinion angle isn't straight, could that be the problem? I'm hopping it's not the trannys, as my suburban is sitting parked with a blow 700r4 right now :(
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    does the shaking go away? most likely if it was your pinion angle it would happen all the time not just when it shifts from 2nd to 3rd. sounds like a tranny problem to me. once mine had a problem like similar to that. you know the shaking and jumping you get when you let the clutch out too fast on a standard tranny? thats what mine would do and it turned out to be a bad torque convertor that resulted in a destroyed transmission. the insides were so torn up that I had to transplant all the internals out of another transmission.
  3. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    Might need to balance the rear driveshaft. I have a similar problem. At 2k rpm in 3rd, I get a nasty vibration. By 3k rpm, its almost undrivable. Right now I just avoid higway driving.
