Transmission Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by caryhenry, Jan 5, 2003.
  1. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    My question is this: I have a 700R4 tranny, and I wanted to know if a th350 tranny will bolt up to the engine and transfer case the same, or would I need to make modifications....
  2. 83_K5
    83_K5 Registered Member
    Aug 9, 2002
    5
    Iowa
    I know that the 350 is about two inches shorter than the 700r4, but other than that everything will line up. Advance Adapters makes a spacer that goes between the tranfer case and the rear of the trans and makes it work. My K5 had been converted to a 350 trans before I bought it and I converted it back to the 700r4 for the obvious reasons. /forums/images/graemlins/k5.gif
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    My friend swapped a 350 with a 700R4 and he had no troubles. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  4. caryhenry
    Sep 28, 2002
    78
    Tallahassee, Fl
    did he use the adapter, or did it match up?
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It should go right in with that adapter that was mentioned. I had this setup for a while on mine.
