transmission question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevytruck75guy, Mar 16, 2003.
  1. chevytruck75guy
    chevytruck75guy Registered Member
    Mar 16, 2003
    14
    hey,
    i am new to the board and building 4x4's(only 17 years old). my 1975 k10 has a bad turbo350 in it. i was looking threw the trading post for a new one so a guy at my work can rebuild it and noticed alot were sayin that it was a short or a long shaft. what exactly dose that mean? one other thing, i can take a 2wd tanny take off the end shaft and put it in my 4x4. right? sorry it the questions sound dum but i am still learning about these things.
    thanks /forums/images/graemlins/truck.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    First of all, welcome to CK5. Pleasee take a momment to fill out your profile. It'll help us help you. Who knows, there might be someone in your area with a tranny for sale. If you have someone that builds trannys, maybe you should have him just rebuild the one you already have.
  3. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    ok first off welcome. secondly the short and long shaft are for the tail shaft of the tranny(part the drive shaft yoke slips over. thirdly i am not positive on this but i don't believe that you can use a 2x tranny in a 4x ok hope this helps. also like Z3PR said just rebuild the one you have its a good tranny to build cheap.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You can't *just swap* output shafts, you have to take the trans completely apart to do it. The first thing that goes into the case when assembling it is the output shaft. "Short" and "Long" shaft do refer to the output shaft used. In the 4x4 case, the length of shaft is determined by the tcase and adapter used. For a 2WD, you just need the right tail housing and output shaft for the drive shaft length.
  5. chevytruck75guy
    Mar 16, 2003
    14
    thanks on the answers. i would use the same tranny but he case is crack so its pretty screwed. i work for a ford dealership training to be a tech and i got the transmission guy in there to give me a good deal on therebuild. now i have a good idea on the type of transmission i can get, thanks again /forums/images/graemlins/truck.gif
