transmission question
Discussion in 'The Garage' started by tankntwankies, Jan 28, 2004.
  1. tankntwankies
    tankntwankies Registered Member
    Sep 13, 2003
    11
    i've got a 77 k5 and it just revs in reverse.. could that have anything to do with the t-case? cause i have problems getting it to drive in anything but 4 hi...or will i need to put a new tranny in it and if so what is a good choice for a tranny
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    That post is kinda broad ranging. Assuming you have an automatic, it sounds like its toast. Although you could have some trash or something sticking up a valve or passage.
    For an auto tranny, I would go with a TH-400, for a manual, depending on preference, go with a SM-465.
    With a little more information, someone or myself may be able to help you a little more. /forums/images/graemlins/waytogo.gif
    John
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    It's really hard to help when ya didn't mention what transmission you have.
    An automatic in reverse usually the foreward clutch and low/reverse band are applied.. So if you have slipping issues in like foreward gears 1, 2 or 3rd gear the foreward clutches are probably burned, the way to test the low-reverse band would be to manually shift it down into 1st gear, then accelerate up to about 20-25 and let off the gas- you should have engine braking in 1st gear and it should slow you down by letting of the gas if your low/reverse band is working...
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/confused.gif
    What tranny? Any other problems? The ONLY complaint is -No reverse?
  4. tankntwankies
    Sep 13, 2003
    11
    its got an automatic th350 right now
  5. tankntwankies
    Sep 13, 2003
    11
    its done this before...but when i added transmission fluid it shifted into reverse fine.. but this time it wont work that easy. the only other problems i have is it doesnt seem to drive either direction in anything but 4wd
