transmission questions
Discussion in 'The Garage' started by rich01, May 14, 2003.
  1. rich01
    rich01 Registered Member
    Mar 26, 2003
    19
    ATL Ga
    i started experiencing problems with my transmission last week where it was having trouble switching gears. that led to not switching out of first gear and now it currently will not move in drive. it is a th400 and is in an 84 m1009. someone told me it was the governor but im not sure that that wouldnt allow you to not go in drive. anyone who has comments or info please respond.
    thanks
    rich /forums/images/graemlins/k5.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it may sound stupid but is it full of fluid? what color is the fluid?
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the first step would be a simple changing of the fuild and filter. a clogged filter can cause this.
    second, make sure the kickdown cable is attached and functioning properly and put a new gov. in.
    Last, your screwed, buy a new tranny.
    have a nice day.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    There is no kickdown cable on a TH400 so dont worry about that.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    cool. my damned Th350 has one that comes off now and again...
  6. dyeager535
    26,982
    191
    Governor is driven off the output shaft. If the tranny mount move, it's not the governor.
    Governor problems affect shifting, but do not prohibit movement if they aren't working correctly. (IE moves, but won't shift out of gear)
  7. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Similar problem here but with a 350. I put it in drive and when it shifts out of first gear into second nothing there. I havent driven it far since I noticed it so I was planning on doing the fluid and filter thing. It also is making a hissing sound. I was wondering about vacuum modulator? Guess I will have to crawl under it again.
  8. rich01
    Mar 26, 2003
    19
    ATL Ga
    mine is making the same hissing sound and i was also thinking the vacuum mod but i still havent had time to check anything out.
