transmission rear mount destruction
Discussion in 'The Garage' started by Gacrawler, Jan 12, 2007.
  1. Gacrawler
    Gacrawler Newbie
    Jan 12, 2007
    Atlanta Georgia
    Gentlemen; I am on my third rear mount and just sheared the rigid steel rod on the right side that connects the transfer case to the bell housing engine joint. 1986 K5 383ci 700r4 6"plus lift 4:56 gears. Any ideas
  2. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Sheesh. Try going with urethane engine and tranny mounts. The strut rod from the xfer case will need to be replaced else the case may crack (208/241) if it has not already.
