Transmission Rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by maxq15, Jun 1, 2001.
  1. maxq15
    maxq15 Registered Member
    May 16, 2001
    44
    Miami, Florida
    Well, after 190,000 miles, my 700R4 finally gave it up. I just had to have a soft overhaul and not real happy about the expense, but in the grand scheme of things, it's alot less than making payments on a characterless new vehicle.
    Question: what future preventative maintenance would help me get the longest lfe out of my rebuilt trans?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Running a cooler, and installing a drain plug kit or get a deeper pan with the air fins and the drain plug.
    this way you can change the fluid on a more regular basis.
    I have been changing the tranny fluid every 3000 and then swapping the filter out at the 10,000 mark.
    With the drain plug it makes it super easy versis the old way.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  3. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    where do you install the drain plug? and wouldn't it be wise to change the filter? I changed mine out when I first got it.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I think you can go 25,000 on tranny fluid and the filter. Putting a drain plug in it is a good idea cause it's a big ol PIA when you're pulling the pan and tranny fluid is running in your face and down your arms and stuff.
    Anything to make the tranny run cooler will help. The finned pan will help, but mostly the cooler will help. I noticed much firmer shifts when I put mine on right away!
    <font color=red>I'm a psychic amnesiac. I know in advance what I'm going to forget. </font color=red>
  5. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    See if a shop in your area has a T-Tech machine. This thing rocks. It blasts 14-16qts through the entire system (cooler, lines etc) to clean it all out before replaceing the ATF. I've seen POS trannys get "reborn" after a t-tech session. Definitely worth the expense IMO.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  6. maxq15
    May 16, 2001
    44
    Miami, Florida
    Thanks for the advice. I replaced the original pan with one that has a drain plug in it and am having the transmission cooler installed next week. I will see if I can find a T-Tech machine in my area, sounds like it would be worth the search.
    Thanks!!
    Those who think money can't buy happiness don't know where to shop.
