Transmission removal questions
Discussion in 'The Garage' started by wedge, Jan 12, 2003.
  1. wedge
    wedge Registered Member
    Jan 5, 2003
    6
    Michigan
    The front seal in my '72 K5 "Top Loader" 4 speed trans is leaking. How do I remove the Shift lever from the top of the trans? Also, does it make since to remove the transfer case prior to the trans because of weight?
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Once you get to the top of the trans (after removing shifter boots etc), you need to depress the metal piece that fits in the "neck" of the trans, and rotate it in the only direction it will turn. Since its sping loaded, it should pop up at you once you've turned it far enough. Hope I didn't just confuse you further! /forums/images/graemlins/wink.gif
    -Dan
  3. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    As far as spliting the trans and transfercase it depends on your jack. If you are useing a plain floor jack then yes split them and becarefull. If you have a good trans jack then you can leve them togather.
  4. wedge
    Jan 5, 2003
    6
    Michigan
    Thanks Dan, it worked like a million bucks! /forums/images/graemlins/smile.gif
  5. wedge
    Jan 5, 2003
    6
    Michigan
    Thanks for your advice, I think I'll rent a trans jack in the morning!
  6. great scott
    Dec 31, 2002
    333
    Utah
    Have fun
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The trans jack is the only way to go. I dropped a 208 on top of me once. turns out that renting them is not that expensive.
  8. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    dropped a 208 once and only once on me....On my elbow!!!!!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif Thing still bothers me sometimes to this day, since that day I forked out $70 for a tranny jack from harbor frieght, never regretted it a bit since... /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
