Transmission Replacement
Discussion in 'The Garage' started by zooexhibit, Apr 29, 2003.
  1. zooexhibit
    zooexhibit Registered Member
    Apr 29, 2003
    10
    Arvada, Colorado
    Hello all I am planning to replace my existing sm465 manual transmission with and 3 speed automatic transmission. I have been looking around and so far I have been told that I should use a rebuilt th400 turbo because it will mate right up to my transfer case, whereas the th350 would require me to rebuild/modify the transfer case. I have also been told parts would be about 900 dollars, but to have it installed could be as mush as 2500 dollars. I was also told that I can do this replacement myself without to much difficulty. I consider myself to be a rookie when it comes to auto repair. I wonder if anyone can confirm the information I have recieved so far, and does anyone have any pointers about doing this replacement. /forums/images/graemlins/k5.gif
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    If your Tranny is the original one for your truck then your T-case will not bolt up to a TH-400. Your SM465 should have male 10 spline on the back of it while a TH-400 would have 32 spline female. Your best bet is to find a TH-400 with a t-case already mounted on it.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Sounds like somebody is out to bend you over. You could most likely do a trade deal with somebody on this board for most of the stuff and then its time spent.
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    If you're talking about the 72 K5 in your profile, the 465 should be a 10 spline output if connected to a 205 transfer case. I believe all T400 were 32 spline output, but Advance Adapters can sell you the need adapter. If you have a 205, it will be 10 spline input. But you could have a Dana 20 also. Not sure of spline count with these.
  5. zooexhibit
    Apr 29, 2003
    10
    Arvada, Colorado
    Sorry I do have a np205 transfer case.
  6. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Why replace it? Your not going to gain any gas milage by switching to the 3 speed auto, and the sm465 is WAY stronger.
