Transmission shaft Selector seal replacement
Discussion in 'The Garage' started by ntx78k5, Nov 14, 2005.
  1. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    Its leaking and snap on has the tool to replace for $26.90 + shipping to replace without pulling or dropping the pan. Is there another way to replace without spending $27.00 ona tool I will use once?
    TH350
  2. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    TTT with all the experience on here someone has to know something
  3. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    Having the right tool for the job takes about ten minutes. That is assumong you stop for a cold drink. I haven't found an easier or better way. Good luck.
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Does the tool come with pretty good instructions? and what's a good source for the seal?
  5. 84zz4ss
    Dec 28, 2004
    1,342
    Pensacola FL
    Instructions.
    Screw remover to seal. While holding remover turn in janb bolt to remove seal. Install seal with install tool and hammer of your choice. For the seal any part guy worth a ____ should be able to find it.
  6. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Now all I have to do is find a parts guy worth a ____ . :doah:
  7. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    ok, so its either buy the tool and save the hassles or let it leak?
  8. 84zz4ss
    Dec 28, 2004
    1,342
    Pensacola FL
    That about covers it.
  9. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    local tranny shop has got to have a dozen or so laying around.
  10. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    What is the part #?????
