Transmission Swap: 700R4 to SM465 What Do I Need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JaymzLD, Aug 12, 2003.
  1. JaymzLD
    JaymzLD Registered Member
    May 22, 2003
    11
    St. Louis, MO/Laramie, WY
    I am interested in swapping out my stock 700R4 automatic transmission in my 1986 Blazer that has the 305 in it for a SM465 manual transmission. What am I going to need? I know I need the transmssion, the clutch pedal and probably a new brake pedal, shifter, bellhousing, and a 465 to NP208 adaptor. Is there anything else I am forgeting? About how much can I expect to pay for everything except for the trans? Where can I get some of this stuff? I have never done anything like this so any help would be greatly appreciated. Thanks.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    id go to the local bone yard and get everything there or find someone that is parting out a truck with one in it also why not get one with the np205?
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You'll have to change the input gear on your current 208 to keep it. SM 465 is 10 spline or 32 spline (TH 400 is 32 spline too) 700R4 is 27 spline.
    I wouldn't keep it. I'd swap to a 205 like I did.
  4. JaymzLD
    May 22, 2003
    11
    I didnt even think about that. Is it that much easier to just swap the transfer case with the transmission? If so, I may do that. Is there anything else I should know about doing a swap like this? Thanks again guys
  5. JaymzLD
    May 22, 2003
    11
    Is the 205 any better or worse than the 208? Or is just that it would be easier than keeping the 208?
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the 205 is a lot stronger and is all gear driven unlike the 208 that is chain driven also the 205 is a part time case so you don't need to do any mods to make it a part time case /forums/images/graemlins/thumb.gif
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] The 208 doesn't need any mods either because it is a part time case also.
    85k5,3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  8. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    You aren't concerned about losing your overdrive?
  9. JaymzLD
    May 22, 2003
    11
    Eh... not really. I would rather drive a manual w/o overdrive than an automatic w/ overdrive. Is overdrive that special that I shouldnt switch transmissions? I MUCH rather prefer manuals over automatics so the choice is clear in my mind, I just need some help with it /forums/images/graemlins/cool.gif
  10. dyeager535
    26,979
    Don't feel bad about losing OD. Started out with an '83K5 with 305/Q-jet/700/208/3.08's/31" tires, and now have a conglomeration of years 350/q-jet/465/205/3.42's/33" tires, get 1MPG freeway BETTER, and about the same in the city. Both engines had over 100K on them FWIW, both carbs were rebuilt by me.
    Funner to drive (both in power and shifting), more reliable, better crawl ratio, and better economy. Go figure. /forums/images/graemlins/smile.gif
    Keep your eyes open for an '85-later truck with manual in it. Grab ALL the hydraulic stuff for it, and if it's 4wd, grab the tranny and t-case.
    I wouldn't toss the 208 until it broke, and since you still need a tranny, might as well buy a set. (and have a spare t-case : )
    Of course a later 465/205 combo would be nice, but the 208 does have some slight advantages (probably more efficient and has a lower low-range), and if you can find a matched 465/208 set, go for it. Then the 4wd linkage isn't an issue, if you are keeping the truck relatively stock.
  11. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    You will also need a flywheel and clutch assembly to replace your flexplate and torque converter. The brake pedal and clutch pedal come in one assembly. You will need all the linkage with the pedal, including a master cylinder, slave cylinder and the tubing between them for the swap. Or, if you go with a mechanical clutch setup, you will need all the mechanical linkage form the pedal to the clutch fork. Be sure and know what kind of clutch assembly the bellhousing and clutch fork came from (hydraulic or mechanical). The bellhousings and clutch forks on the two are different.
    You would definitely be best to find a donor vehicle with everything on it and do a complete swap (pedals, linkages, flywheel to tcase) if you can. That would definitely be the easiest way. Too bad you didn't say sooner. I am converting my K20 to a 700 from a 465. I just sold everything (I mean everything) including the tcase!
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i have almost everything you need to do the swap. e-mail me if you are interested.
    Grant
  13. JaymzLD
    May 22, 2003
    11
    Whats the difference between a hydraulic or mechanical clutch? Is one better than the other? Which came in what years? If I were to go to a local junkyard, would I be able to just take everything from the clutch pedal to the shifter from another truck and have everything bolt in fairly easily? I want to do this by myself (with the help of a couple friends of course), but I have little experience with this kind of stuff so I dont want to get in waaay over my head. I have another car so downtime wont be too much of an issue. Thanks again guys /forums/images/graemlins/thumb.gif
  14. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    wow this ones smart someone give him a prize! /forums/images/graemlins/rolleyes.gif
    lol jk /forums/images/graemlins/rotfl.gif
  15. dyeager535
    26,979
    Hydraulic clutch is made for your truck. The dimples are in all the right places to make install easy.
    Don't like mechanical clutch setups myself, although I do know they can be fine.
    '85-up is the hydraulic setup. Wait for it. Believe me, it's worth it in your case.
    A hydraulic swap is a no-brainer. Unbolt from donor, drill/cut a few holes, install, done. It will take some time, but it's not complex.
    My '81 frame was not setup for the mechanical clutch (apparently this may be somewhat unusual) so I had to drill the spots on the frame for the z-bar bracket, and that was with the body off. Most people apparently have the holes in the frame, but as late as yours is, it MAY not.
    With a normal drill, I don't believe I could have drilled the frame for the manual clutch with the body in place.
    You don't want a 3-finger clutch either, go with the diaphram. Smoother apply makes driving a lot more enjoyable. I can start my truck moving in 1st (as marked on the shifter) without using an ounce of throttle, and move out smoothly...my dad's with the 3 finger clutch can't.
  16. JaymzLD
    May 22, 2003
    11
    3-Finger?? Diaphram? I have no idea what you mean by that.
    And Bryguy... yeah I dont know everything about trucks and I dont claim to, so I come here for help. So fvck off /forums/images/graemlins/smirk.gif
  17. dyeager535
    26,979
    3 finger clutch is I believe rightfully called a borg and beck style. It only has 3 large "fingers" that meet up in the center. A diaphram clutch has many more "fingers" that run into the center. I assume GM used the diaphram style starting at some point, but typically older applications were 3 finger.
    A little less "holding power" apparently, but I've experienced no problems with the diaphram style, and vs. the 3 finger/mechanical setup my dad has, mine's better, hands down. (and not just because I own it : )
