Transmission swap questions
Discussion in 'The Garage' started by Myke, Nov 30, 2006.
  1. Myke
    Myke Registered Member
    Sep 3, 2006
    31
    New Jersey
    I have an 89 K5 w/ the 700-r4 but it's slipping. Can I just swap the 700-r4 from a 1983 Chevy S10 Blazer 4x4 2.8L V6. The guy only wants 250 and it was recently rebuilt. Sound like a good deal?
  2. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I don't know if the input spline counts are the same or TC stuff is the same but you might want to consider rebuilding the one you got. The 87/88 and up 700R4's are better than the earlier models.
  3. Myke
    Sep 3, 2006
    31
    New Jersey
    All the rebuild kits I have seen are around $500 or so. Do you know of any cheaper kits or is that the going rate? My neighbor is a chevy head and has crazy tools so he already said he will rebuild it with me, but if I can buy one in good condition for a few hundred $$ less I'd go that route.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It will bolt up but the S-10 tranny will get killed behind a 350. We put one from a straight 6 behind a 305 and we killed it in about 4 months. 3rd went out on it and it was all down hill from there. No scientific proof just personal experience. I would say dont do it.
    Ira
  5. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    the bellhousings are different on the 2.8 the the 2.8 is a 60 deg. while the 350 is a 90deg. only thing that will interchange is the 4.3 v-6
  6. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    There ya go. moot point. :D
    I found a "performance" rebuild kit that was only like 600. I would imagine a standard rebuild should be less. Do a quick search and you should turn up some reputable places to order your parts from.
