Transmission swap
Discussion in 'The Garage' started by Sander, Nov 23, 2006.
  1. Sander
    Sander Registered Member
    Apr 14, 2005
    20
    The Netherlands / Europe
    My 1979 K5 Blazer has a TH350/NP203 combo. The transmission needs overhaul. I have a TH700R4/NP208 combo with only 2000mls on it lying around. Would that be a straight swap out or do I need to relocate support brackets on the frame?
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    iirc, the th350 is shorter than the 700r4, so you might have to move the crossmember for the trans back some... definately not undoable
  3. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    Driveshaft lengths will be different also.
