Transmission Temp?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Texas76, May 25, 2000.
  1. Texas76
    Texas76 Registered Member
    May 24, 2000
    26
    Texas
    Does anyone know what the correct operating temp for a T350 tranny should be? Thanks for your help.
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Depends on where you are taking the measurenent !
    For max life the fluid temp should be above about 155 F and only go to 200 F for very short periods of time
    (like towing a heavy load).
    So if you have a way to regulate is set it for 180 F and you'll be good to go.
    And if you don't have a way to regulate it good luck
  3. Texas76
    May 24, 2000
    26
    Texas
    I am planning on installing a tranny cooler. Are there problems with the tranny cooler keeping it too cool? This will be a "trails only" vehicle, not a daily driver. But, I don't want it to get too cool during the 6 hour drive to the mountains.
  4. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    I seem to remember reading this somewhere else in the post. If you install a tranny cooler it still needs to go through the radiator. This is to help heat it up when its cold and your engine temp is regulated anyways. I believe it should go through the cooler then the radiator this way it will take a load off of your coolant system and in turn reduce tranny temp. This seems to make sense but its only my 2 cents. Poet and didn't even know it ha.......
    Blood, sweat, tears, and lots of money is what keeps the k5 alive.
  5. Executioner
    Feb 22, 2000
    1,530
    Don't know, but you bring up a good ?
    Say its 30-40 F outside air, fire up the rig, no long ideal(fuel injection), throw in drive and up to speed in no time
    50-70 MPH, and a lot of cold fresh air over the cooler, and its possilbe to run low ATF Temps.
