Transmission Torque Converter - 350 on a 700R4?
Discussion in 'The Garage' started by bigburban383, Feb 3, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Can you put a 350 torque converter on a 700R4. I understand it won't have lockup, but are there other issues?
    Another thing, summit sells their brand for $90. How much are OEM ones? Would OEM be better then summit brand?
    Thanks /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    just about every thing is the same except for the hub diameter (the part that goes in the seal) the th350 is 1/6 in bigger. you might be able to do it by turning the hub down but then it is thinner and possibility to break it. i can get you a OEM replacement converter for $125 for any thing. the highest stall i can get is 1996
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    also the hub is a little taller on the th350 so that would have to be ground then the groves ground also
  4. dyeager535
    26,979
    Input shaft on a 700 should be different, since it has lockup. TH350C and 700 might share converters, but not the 350 and 700.
